3 members (NorCal52Suburban, klhansen, delky), 58 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,430
#579015 09/30/2009 3:36 AM
My first post so bear with me. My 53 3100 has a 54 235 in it. I just gave it a treat of reworked head (new stainless steel valves,new rods,)put her back together and can't keep a good spark. New coil,new points,new plugs still no spark! When there is spark she starts right up but the dwell flucuates, could it be as simple as a bad set of points?
Welcome aboard. I had the same problem on my '49 3100. Turns out it was a faulty ignition switch. Sometimes the switch worked, sometimes it didn't. Try running a #10 wire directly from the + battery terminal to the coil. This will bypass your starter switch and all the other loose connections under the dash.
Thanks for the idea but it did turn out to be a bad set of points right out of the box. Ole 53 purrs like a kitten now.
