Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 182 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
#57892 03/18/2006 8:13 AM
Apprentice
Apprentice
I'm going to need a rad to fit my '59 fleetside that will cool the 6.2 turbodiesel,not sure if a 6-banger rad will do the job or not.Anyone have any info on rads that will fit the stock '59 rad support,maybe out of a bigger truck?TIA.
#57893 03/18/2006 8:42 AM
the same rad was used 55-59 any size engine - if ya need more than that you'd prolly hafta have a thicker cored one made to fit
#57894 03/18/2006 9:50 AM
Diesels will build up a lot of heat under a big load. Other than that, I don't think their demands are all that greater than a regular engine. You might measure the radiator in the truck against what's typical in a chevy diesel truck and see if there is a huge size difference.
#57895 03/19/2006 1:12 AM
Apprentice
Apprentice
thanks for the tips.!what about rads from say,a 3 ton chev same vintage?any difference there?
#57896 03/19/2006 2:11 AM
rads were alla same 55-59
