0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#578640 09/28/2009 10:44 PM
I
I Offline
My top end of my 350 chevy engine was replaced with all new gaskets. The mechanic told me he was bringing things to top dead center TDC. After putting on a new timing chain and pulley. Was he supposed to pull the camshaft out and reset that crank to ALL the other TDC procedures that were done. I have two pistons sitting in my oil pan now in pieces. What happened ?
sounds like your mechanic messed up. Beyond that couldnt tell you.
Yeah he was. I just built my 350, and you have to put the cam shaft into time before you put the chain on too.
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
Reedster #578655 09/28/2009 11:39 PM
Riding in the Passing Lane
Although I don't quite understand the question, I hope this is not the same mechanic that blew your other engine.
1972 Chevy c10 Cheyenne Super
I think it is one and the same topic, just different posts
That's what I gathered. Or else Iso has a whole bunch of blown 350's laying around...
H Online: Content
If the timing marks are aligned between the cam sprocket and the crankshaft, everything else should fall into place. If that guy is as inept as it seems, I'm not surprised that you had a disaster. Pistons get destroyed for two basic reasons, tight connecting rod bearings that rip the small ends of the rods out of the piston, or badly mis-adjusted ignition timing that melts the tops out of the pistons. A severe vacuum leak on a couple of cylinders will make them run lean enough to damage pistons, also.
