| | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | will the brake backing plates and drums off a 1959 chevy 3/4 ton fit on a 1946 chevy 3/4 ton. because I want to do the bendix brake swap on my truck? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | WOW, maybe- sounds like a great idea, let us know. I'm running 57 half ton brakes on the front of my 46 half ton, so why not 3/4 tons also? On the rear you may want the entire 59 axle, may be easier than just the brake stuff.
Do report back on what you learn from this swap.
Best of luck Jim | | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | the front brake backing plates and drums and hubs off a 1959 3/4 ton will bolt up to a 1946 chevrolet 3/4 ton truck. i will have pics by this weekend. | | |
