0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | My top end of my 350 chevy engine was replaced with all new gaskets. The mechanic told me he was bringing things to top dead center TDC. After putting on a new timing chain and pulley. Was he supposed to pull the camshaft out and reset that crank to ALL the other TDC procedures that were done. I have two pistons sitting in my oil pan now in pieces. What happened ?
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | sounds like your mechanic messed up. Beyond that couldnt tell you.
| | | | | Joined: Feb 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 66 | Yeah he was. I just built my 350, and you have to put the cam shaft into time before you put the chain on too.
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Although I don't quite understand the question, I hope this is not the same mechanic that blew your other engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I think it is one and the same topic, just different posts
| | | | | Joined: Feb 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 66 | That's what I gathered. Or else Iso has a whole bunch of blown 350's laying around...
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | If the timing marks are aligned between the cam sprocket and the crankshaft, everything else should fall into place. If that guy is as inept as it seems, I'm not surprised that you had a disaster. Pistons get destroyed for two basic reasons, tight connecting rod bearings that rip the small ends of the rods out of the piston, or badly mis-adjusted ignition timing that melts the tops out of the pistons. A severe vacuum leak on a couple of cylinders will make them run lean enough to damage pistons, also. Jerry
