8 members (Gdads51, Steelonsteel, TUTS 59, Mike Burns, Mike'sPlace, Wickedbass, moparguy, 1 invisible),
98
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I have a '47 216 that has been converted to 12 volt. Are the points and condenser the same as if it was 6 volt? Thanks
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes they are the same. I think there is an old post on this. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, but you will need to put a resistor inline with the coil to keep it from overheating.
