3 members (papas52, BobbyV, Gib70), 111 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
If a person was ever stranded could you jump start a 6 volt system from a modern 12 volt system vehicle ? Thanks
It's not the speed you travel it's the quality of the trip that matters !!!
yes .... best not to have the 12v vehicle running, and don't leave them hooked up any longer than necessary to do the job - if there's a problem, it'll more likely be with the new computerized vehicle wink
H Online: Content
I would reccomend disconnecting the battery on the 12 Volt vehicle to avoid any possibility of a voltage spike damaging the alternator or the computer. Of course, if it's an old-school rig with a generator and a point-type distributor that just happens to be 12 volt, no problem. Don't make any sparks around the top of the hot battery, as that's inviting a hydrogen explosion. Get the cables attached to the top of the 12 volt battery first, then attach the + cable to the top starter connection, then put the - cable somewhere that's a good ground like the generator bracket, etc. You'll get some pretty nasty sparks as the ground is connected because the 12 volt battery is going to start fast-charging the 6V immediately. Don't stay hooked up for long!
As was mentioned earlier, don't leave them hooked up long. Its better to make it a 2 man job. Hook her up, have the other guy immediately hit the starter, and immediately disconnect it. I now use the 12 volt emergency starter kits that are sold every where. At least I don't have to worry about screwing up an alternator or ecm.
