| | | Forums66 Topics128,108 Posts1,056,565 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 36 | If a person was ever stranded could you jump start a 6 volt system from a modern 12 volt system vehicle ? Thanks
It's not the speed you travel it's the quality of the trip that matters !!!
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes .... best not to have the 12v vehicle running, and don't leave them hooked up any longer than necessary to do the job - if there's a problem, it'll more likely be with the new computerized vehicle  Bill | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | I would reccomend disconnecting the battery on the 12 Volt vehicle to avoid any possibility of a voltage spike damaging the alternator or the computer. Of course, if it's an old-school rig with a generator and a point-type distributor that just happens to be 12 volt, no problem. Don't make any sparks around the top of the hot battery, as that's inviting a hydrogen explosion. Get the cables attached to the top of the 12 volt battery first, then attach the + cable to the top starter connection, then put the - cable somewhere that's a good ground like the generator bracket, etc. You'll get some pretty nasty sparks as the ground is connected because the 12 volt battery is going to start fast-charging the 6V immediately. Don't stay hooked up for long! Jerry
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | As was mentioned earlier, don't leave them hooked up long. Its better to make it a 2 man job. Hook her up, have the other guy immediately hit the starter, and immediately disconnect it. I now use the 12 volt emergency starter kits that are sold every where. At least I don't have to worry about screwing up an alternator or ecm. | | |
