9 members (Peggy M, Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, 1 invisible),
69
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Will a 48 216 bolt up to a 54 3spd trans? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, if you are referring to an enclosed drive-shaft 3-speed.
Use your 48 clutch housing and clutch assembly (including the throw-out (release) bearing.
Note: you do not say what transmission you had on your '48: the 3-speed and the 4-speed enclosed drive-shaft transmissions have different u-joint yokes at the transmission end of the u-joint assembly.
Tim | | |
