1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#577875 09/25/2009 7:32 PM
V
V Offline
Will a 48 216 bolt up to a 54 3spd trans? Thanks
Yes, if you are referring to an enclosed drive-shaft 3-speed.
Use your 48 clutch housing and clutch assembly (including the throw-out (release) bearing.
Note: you do not say what transmission you had on your '48: the 3-speed and the 4-speed enclosed drive-shaft transmissions have different u-joint yokes at the transmission end of the u-joint assembly.
Tim
