1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57787 03/16/2006 6:04 AM | Joined: Oct 2005 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 43 | Anyone know if a '58 235 head will fit the 1st serries '54 261 block and will the '54 water pump work? | | |
#57788 03/16/2006 6:49 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Yes - that head should work on a 54 261. The pump will work with any head you put on that engine. The fact that the pump is higher than the later models makes no difference. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#57789 03/16/2006 12:05 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | ROUGIE I'm not sure but you might need to drill some holes in the 235 head to match the ones in the 261 block, As the 261 has holes between each cyl on the top of the block. check the head gasket  | | |
#57790 03/16/2006 8:22 PM | Joined: Oct 2005 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 43 | | | |
