5 members (Bill Hanlon, rfs56trk, Hotrod Lincoln, Jon G, Hush), 126 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
#576894 09/22/2009 7:52 PM
Does anyone know where I can buy NEW springs for my Rochester B? I got a rebuild kit from NAPA, but it didn't come with a power piston spring, or a power piston check ball spring and I'm 90% sure that both of mine have been squished a little.
Does anyone know what the length of the power piston spring is supposed to be for a 54'?
I know that Carbking sells them, but I don't know if they are new, and you have to buy a $50+ rebuild kit before he'll sell you a spring for $8.
The NAPA kit comes with a little football shaped spring, is that the power piston check ball spring? It doesn't look anything like the one I took out.
Thanks Guys
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
bump...
I'm guessing this means that new spring aren't availiable?
Bryan
Has anyone tried shimming the old springs with any success?
Bryan
Carburetion specialist
Thanks Guys
The springs sold by carbking are new, and custom-made for carbking in the USA.
Jon.
The Carburetor Shop
Power piston springs come in 2 lengths depending on the carb. 2-3/16" for carb 7001374/7002050 and 2-17/64" for carbs 7002051/7003060. This info is found at: chevy.oldcarmanualproject.com in the "manuals listed in order of year" section under 1950 "Servicing GM Model 'B' Carburetor". Another way to get springs is to buy old carbs online for parts. Good luck!
Ed
