9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53),
236
0
Mod | | | Forums66 Topics128,101 Posts1,056,172 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Does anyone know where I can buy NEW springs for my Rochester B? I got a rebuild kit from NAPA, but it didn't come with a power piston spring, or a power piston check ball spring and I'm 90% sure that both of mine have been squished a little.
Does anyone know what the length of the power piston spring is supposed to be for a 54'?
I know that Carbking sells them, but I don't know if they are new, and you have to buy a $50+ rebuild kit before he'll sell you a spring for $8.
The NAPA kit comes with a little football shaped spring, is that the power piston check ball spring? It doesn't look anything like the one I took out.
Thanks Guys
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | bump...
I'm guessing this means that new spring aren't availiable?
| | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Has anyone tried shimming the old springs with any success?
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Does anyone know where I can buy NEW springs for my Rochester B? I got a rebuild kit from NAPA, but it didn't come with a power piston spring, or a power piston check ball spring and I'm 90% sure that both of mine have been squished a little.
Thanks Guys The springs sold by carbking are new, and custom-made for carbking in the USA. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Power piston springs come in 2 lengths depending on the carb. 2-3/16" for carb 7001374/7002050 and 2-17/64" for carbs 7002051/7003060. This info is found at: chevy.oldcarmanualproject.com in the "manuals listed in order of year" section under 1950 "Servicing GM Model 'B' Carburetor". Another way to get springs is to buy old carbs online for parts. Good luck!
Ed
