7 members (walterhvogel, Jman, Tom McGrath, UtahYork, Materman, Rich'sToys, Wally / Montana),
107
Mod | | | Forums66 Topics128,035 Posts1,055,557 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | I know that everyone has seen the 12v converter to 110. Well I went out and pulled the set in the 52 and found the original jack. and this converter. Its a 6v Allstate current converter with output of 110 at 30 watts cont. Have never seen one of these or even heard about them before. How about any input as to what year it may have came out. Hooked it up to the battery charger and it works. will try to get a pic of it and link it. ????? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | actually that's an inverter [DC to AC], as used in RV's so probably around since travel trailers started Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Cool! I don't think 6v inverters are made any more so if you don't want it you might be able to ebay it for some folding money.
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | It sounds worthless, and dangerous. Fortunately, up in Canada here, I just completed a rigorous training course on how to deal with these. You'd better send it on up.
Cool! Now, you can find an old Remington razor, and shave while you drive!! | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | The only problem I see is the 30 watt rating- - - -half the capacity of a table lamp bulb! Are you sure that's all it's able to produce? There are very few 110 Volt accessories I can think of with a power draw that low. Jerry
| | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Maybe he meant 30 amps? But that's too high for a poor old generator
Very cool score...I'd love to have my original jack.
Saw something really cool at a car show last weekend. 50's era Road flares! basically little tiki torches that sit on the pavement...jealous
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Finally got the computer to work right here is a link to pics on photobucket hope you can read the label. not very big. 40 watts intermitent. 30 watts cont. 6volts d.c. input 110 volts a.c. 60 cycle posted as converter and not inverter because thats what was on the lable | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Still cool. I've never seen one.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You one lucky dude dakota, I've been looking for one of those for a couple of years. Of course they don't make them anymore, the problems you run into with converting those AC devices is the current draw. It's quite high with 12v but twice as bad with 6v. I have a 500w continuous 12v Whistler inverter that I could power up the tube radios with when I was into radio collecting. My jumpers were #8's to the 12v battery. If that had been a 6v with that output capacity it probably would have needed battery cables to connect it up to the battery. Most old radios would have drawn from 100w to 300w power. I'd love to see what was inside that 6v inverter. It was probably before the solid state divices came along, so there had to be some kind of vibrator built into it and it's probably mostly transformer. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I would be surprised to find much more than a vibrator, transformer and rectifier tube. I have no clue what a person would do with 30w of ac power. About the only appliance that I remember that pulled that little power was an electric clock. The 60 cycles would make a clock be very accurate compared to the windups. | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | i picked up what looks like a typical, old '50s-'60s vehicle's generator, that would as usual, bracket-mount to the front of an engine, pullied into the fan belt, but it puts out 110v/60hz ac. and it works | | |
