0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I'm installing my new wiring and wondering how in the heck to run the new wire to the domelight. The old wire is long gone. This looks like a real challenge, any ideas? | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Well how are you at fishing? Wire that is - get some steel coat hooks and find holes and stick em in and somehow get em close and hook em together or use string on end an pull coat hook and string thru.
Almost forgot -- undo the coat hooks and straighten they go in a lot better.
Dan Bentler | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | An old speedometer cable makes a pretty good fish tape to try to run up through the windshield frame post. You can twist it a lot without getting any kinks. Be aware that you'll prpbably encounter some dead end passageways before the cable finds the right opening. Once it's all the way through, tape a wire on and pull it back through- - - - - -carefully! Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A nylon string (braided, not monofilament)can be blown through the hole with air. Then tie it onto your wire and pull back through. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Wire from a wire feed welder works well, too. I found it is easier with the headliner out. You can fish the stiff wire throught the A pillar from the space between the inner and outer roof sheetmetal with the headliner out easier. Onece you get the wire that far, getting ot the dome light is relatively easy. Used the same technique to get the wiring to the radio speakers, which mount in the OE location above the mirror.
Bill Burmeister | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Be sure and run two wires for the dome light.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Thanks for the tips guys. My headliner is out so hopefully that will a little bit. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I used an electricians fish wire. A little tricky but works fine. Best of luck.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I spent all day on the dome light but I finally fished the wire through only to discover that the contact for the dome light on my headlight switch was broken. Swapped in a spare headlight switch and voila! Light!
Thanks for all your help. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | coat hanger wire lashing wire bailing wire fish tape mig wire
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
