Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Hush), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#577232 09/23/2009 4:29 PM
I have a queston will a 56 truck third member bolt up to a 51 torque tube rearend so I can get ride of the torque tube?
SlickT
Slickt #577241 09/23/2009 5:20 PM
Yes, if it's from a 1/2 ton.
Steve
'49 3800
'52 3600
'57 3100
It is from a 1/2 ton. THANKS GHOSTRIDER !!!!
SlickT
Slickt #577261 09/23/2009 6:08 PM
You will have to weld up your suspension because it pivots and the torque tube is what kept it from winding up.
crenwelge do you mean weld up the leaf spring shackles ?
SlickT
