0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
Late 30's chevy pickup owners,
Will a 292 inline six fit in a 38 chevy pickup truck engine bay without major modifications? Will it require moving the stock location of the radiator? What about fan clearance?
I'm new to this stuff, as always I appreciate any info/experience you all have.
oldbald2 aka
Don B
cant help on the fan clearance, however the mounts are different on the 292 vs any of the other I6's
The 292 is longer, but in my '39 there is room to move the radiator forward. Instead of that, though, I recessed my firewall and left the radiator where it was intended. Check out the Sept. '09 Classic Trucks magazine for a new firewall install.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
I moved my radiator forward and recessed the firewall. I have more room then I needed, but at least the firewall stays a cooler now. I also set my engine a little high so I had to hump up the floor board to clear the automatic transmission. If I was doing it again, I would keep the floor as is and set the engine -trans just low enough to clear and as far back as I could.
You find the room in the cab is quite small, so any that you can keep, keep it! With a hump in the floor, the throttle pedal is a little farther to the left then I wanted, so it takes some getting used to when driving.
Joe
Quote
The 292 is longer,
I beg to differ
a 292 is .. NO .. longer than any L6 , 194,216,230,235,250,261
w/ the exception of 302's & 308's. taller than most by 1.75'', lighter than 216 & 235's
some had 2 & 3 groove pulleys
you can find a 1 groove pulley.
they have a V8 type bell housing as opposed to the 216/235 one
i have a pusher fan on my 292 radiator
Jim & Caroline
Block may be the same, but you have to take into account the attachments. Isn't the water pump longer therefore making the engine assembly longer?
CK
It seemed to me it was longer, I had to notch the fire wall to get mine in. I have seen the picture in Leo's book of 1963 230 overlayed on the 1962 235, and the 230 is smaller, shorter and 19% lighter so GM said. Maybe they are the same, but clearance sure is tight, maybe they were with the original engine to.
Joe
