10 members (dwreills, Gdads51, 32Fordpuchoptop, chevy51truck, Phak1, klhansen, 52Carl, KEVINSKI, Woodcmiami, 1 invisible),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | I wish to lower my 60 c10 apache but it has a torsion bar front suspension rather than a coil spring. has anyone any knowledge or experience in dropping this type of suspension?????? | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | yes, several have done it. i think you can easily lower it a couple of inches by tightening it down. the rear isn't as easy. | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Several ways. For the front, I've heard that the torsion bars are adjustable...but lube up the adjusting nuts and threads really good before attempting to loosen them. I hear that those parts are next to impossible to find if you break them. Also, there's drop spindles available for this truck. It does require you to convert to front discs, which also means a new master cylinder with booster is needed, and if your truck is a manual with hydraulic clutch, the aftermarket master is pretty pricey. This is what I'd like to do with mine, but the cost of it is stopping me from going ahead with it at this moment. As for the rear, it's like any other truck with coil springs. Drop coils and shorter shocks should do the trick.
| | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | thanx, I will loosen them up, if I tighten them it will raise the truck. then I shall put in a disk brake conversion on the front and 3" drop springs in the rear this all new will run about $1600 from lmc truck..... | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Even including the master cylinder? Or is yours an automatic? (no hydraulic clutch) | | |
