Just cleaning out the garage today, I took
Ole Booger out for a spin around the neighborhood. That was MUCH more fun than just backing it out of its home in the garage.
Normally when I park it for a bit, I disconnect the battery via the knife switch that I installed a while back. I didn't bother this time.
After working a while in the garage, my wife came out to feed me a pear. While standing there, I heard this faint buzzing in the direction of Ole Booger. I raised the hood to show my wife where I mounted the AOOOgah horn and I heard it again. I bent my head down and listened again next to what I believe is the regulator. It was coming from a small black box mounted on the driver's side up near the horn.
That's the regulator, right? Regardless of the answer to that, why would it be buzzing, or even have power to it with the key off? I had already turned the ignition OFF and removed the key. Hummmmmmm, oh, I mean bzzzzzzzzz, that's interesting.
Rance
