| | | Forums66 Topics128,090 Posts1,056,384 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | i have a couple of 235 engines one out of a car that i want to put in my 52 it a 57 235. i have a 235 out of a truck that has a correct front motor mount. should i drill holes in the original car mount or take off the real motor mount from another engine. that being the case do i have to drop the oil pan to get to the bolts that hold the front mount. thanks Paul | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | if i'm correctly understanding your question; yes, the pan has to be dropped in order to access the two bolts, but i'm confused with the other part of your question | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think if you can drill the holes correctly, that is the easiest way to go. I don't think there would be any point in swapping front plates if you didn't have to. | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Save yourself a lot of work and just drill the front plate. You would also have to remove the cam to do the switch. Just stand both motors on end and transfer the measurements,,,away you go................. Good Luck, Marty | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I would drill the front motor plate.There is a lot involved with removing the front engine plate. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Are you planning to overhaul the engine before it is installed? If so, it would be no big deal to swap the plate, other than dissassembling the other engine. If not, then drilling to match will be just fine.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | hey lb - are there pics available to see the diff between the '57 motor mounts vs the earliers? | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | thanks for all the help drilling the holes it is. The body is off the frame so i will mount the engine and put in the bolts for the rear mounts then drill up into the plates to mark the holes. does that sound like a good idea. thanks Paul | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for the information. I have a 216 from a car that I was going to use in my 53 pickup. I need to drill the holes and was working on ideas to do it.
Like you wodniw5, I was thinking of dropping the engine onto the frame of the 53 and marking where the holes needed to be.
Do I have to use carriage bolts or can the holes be round and I use hardened bolts?
I have a full pressure 235 in the shop being rebuilt. It will have the correct front plate so this 216 is a 'driver' engine.
Thanks for letting me get in on this. Dennis
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Thanks for the information. I have a 216 from a car that I was going to use in my 53 pickup. I need to drill the holes and was working on ideas to do it.
Thanks for letting me get in on this. Dennis Wrench access is limited near the balancer so square holes will hold the bolts in place when tightening but either can be done. Mounting the engine in the frame only to locate the holes sounds like way too much work. I can confirm the template linked above will locate the holes properly provided the holes are laid out to equally straddle the crankshaft centerline. Also from the autopsies I have performed the oil pan nearly always has some degree of sludge in it so I would remove the pan any time a used engine is to be flipped upside down. Good luck.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | flipped upside down? why would someone do that without first removing the oil pan? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | It's probably on an engine stand. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
