10 members (Lightholder's Dad, Hanks custodian, Otto Skorzeny, Gray_Ghost, MickeyP, mick53, Gdads51, KCMongo, JW51, 1 invisible), 95 guests, and 2 robots.
Topics128,049
Posts1,055,658
#576473 09/21/2009 5:42 PM
trying to remove the timeing cover on a 59 235 6.Im prety sure this is a car engine as theres no front motor mount.Do i have to drop the pan?Havent done this in years but thinking theres 2 bolts up in the pan tht need removed.Anybody know? thanks,ron.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
Yes the pan needs to be removed. When you go back with it you can do the old timing cover trick so you won't have to pull the pan next time.
thanks for the ifo cletis,the bolt reversal would have been my follow up.I was hopeing my memory was worse than i thought it was and wouldnt have to drop the pan!Time to get dirty.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
why'd they design it that way in the 1st place?
