4 members (Otto Skorzeny, moparguy, delky, 1 invisible), 104 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#576239 09/21/2009 12:08 AM
Hey guys, I have a 250 that I want to put in a 37 frame. I also wanted to use the stock steering box if possible. Just doing some rough measuring, it looks like motor mounts and steering box want to occupy the same space. Has anyone done this conversion, and was it an issue?
Thanks for any input.
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
Look in the engine and driveline forum - 250/292 swap topic. There are some motor mounts in there that are worth looking at.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
What year manufacture is the 250? Some years have the ability to be nose mounted like the tri-fives plus the mid-engine mounts. Mine was a '71 if I remember correctly and was nose mounted because of the steering box issue. The tranny will need the front brace for support.
It's a 1967 model engine with side mounts. I have since found that Chassis Engineering makes an offset motor mount for the 250 especially for this application. I've pictures of it, and it looks like exactly what I need. Thanks for the info, Jeff
you offset the motor mount call bufillo in washington he is listed in the inliners website
1949 SUBURBAN
