2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I was given a 65 chevy long box with a 235 motor and std. tranny..eight studs on wheels (maybe it's a 3/4 ton??) Can anyone tell me if this motor will bolt into my 46 chevy panel...thanks..
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | It shouldn't be a big problem. You will have to drill holes in the front mounting plate to match your 46 frame(65s used side mounts I think) and use the bell housing & flywheel from your 46 if you are going to keep the orig. running gear. the rest is bolt in. It's a pretty easy swap. Good Luck George | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | It shouldn't be a big problem. You will have to drill holes in the front mounting plate to match your 46 frame(65s used side mounts I think) and use the bell housing & flywheel from your 46 if you are going to keep the orig. running gear. the rest is bolt in. It's a pretty easy swap. Good Luck George | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 235 will fit, and what you have to do depends on the year. 54-early 55 is set up with the correct water pump, later models will need a short shaft pump if you run a mechanical fan.
If your truck has 8 bolt wheels, it should be a 3/4 ton.
Are you sure it's a 235? and not a 230?
Fred 52 3600 69 C-10
#5755 08/12/2003 12:47 AM | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Well now Fred I'm not sure if it is a 230 or 235 all I can see is the two first digits ..seems to be a decal on top of the valve cover..
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The 65 should have a 230, 250, 292, not a 235, unless some put a 235 in it. If it has the original factory engine your going to have a bit more of a problem. Find a casting number.
Regards, Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Are the sides on the valvecover straight and held on with 4 screws (235) or are the sides really curvy and held on with 7 screws (230/250 style)?
| | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I'm not sure how many screws hold down the valve cover..I'm heading back to see the truck next week...I'll check that out..a big thanks to the list...
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think the 230/250 etc. series has a much different looking manifold too. I wonder if anybody could comment on what the gear ratio would be in the rearend and whether it would have a front access pumpkin that would drop into an older 1 Ton or 3/4 ? | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Truckernix, that year is one of the possible donors for a pumpkin for the AD series. However, the standard gears for the 3/4 ton with 4 speed will be 4.57. Usually need to find one with an auto tranny for the 4.10 gears.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | FredT, thanks for the info. Anything is better than 5.14 !
Fred | | |
