2 members (klhansen, TS3600),
131
Mod | | | Forums66 Topics128,166 Posts1,057,012 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | My blower switch is a pull out switch that is located on the bottom edge of the dash, just to the left of the steering column, so that you pull down to turn it on. It sort of looks like it has been moved. Was it originally front mounted so you pull it out to turn on the blower? Where should it be located? I couldn't find the blower switch location in the owners manual. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | being part of an option, it won't be shown in any manual, and it would have been mounted where ever the installer or owner wanted  but any heater fan switches I've seen for that era were either rotary or paddle toggles, yours might be a later addition or an owner repair job? Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If the control (blower switch) you are referring to is for the Air Flow (Fresh Air) heater, and you are referring to the cable-operated control (for defrost), you are describing the correct mounting location. However, the control that I am thinking of does not turn the motor on/off, it turns a "flapper".
If the blower switch is an electrical switch for the fan motor, it is also located in about the same area.
I have a factory installation manual for a 48 Air Flow (Fresh Air) heater and I will look to see if it has a picture diagram for control-locations in a 2-ton truck.
Tim | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Yeah, I am talking the electrical switch. The hole looks poorly drilled, kind of egg-shaped. There are some unused switches on the dash I could probably trade for. I am nut sure what they ran, they were disconnected when I got it. It used to be a fire truck and may have been accessories. I have the defroster control, although the "de" is missing and it says "frost". I was hoping for AC. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Can you post a picture of the hole and/or the switch? I thought that the GM electrical switch was a brown-bodied up-down thumb switch that mounts under the dash. That type of switch might have a brown or ivory thumb-switch. Can you post a photo of your heater? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Here is the picture of the switch. It is between the defroster cable and the steering column, mounted so that it is pulled down to operate. It is just one speed, I think. http://share.shutterfly.com/action/welcome?sid=8Ibs2LFo3bsZe A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | that's not an original switch super, some PO's replacement my 46 had the type TC linked, I call them a paddle toggle
Bill | | | | | Joined: Sep 2009 Posts: 8 New Guy | | New Guy Joined: Sep 2009 Posts: 8 | my switch is to the right of where the radio goes it is a 2 position switch which has been painted over 9 times so it looks original
the know has rounded grooves to fit your fingers but the width is only about an inch wide.
When I grease the muffler bearings it always wants to go backwards and the radio plays classical music ... any suggestions?
| | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | My 53 COE has the paddle switch with an ivory paddle. Body of switch seems to be the BAkelite material. It is mounted next to the defrost control to the left of the column. The switch is mounted with a screw in the top of it. | | |
