| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57558 03/08/2006 7:07 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I am looking for a passenger side Lower Rear Shock Mount for what I believe is a 1957 1/2-ton rear end. Does anyone know of a vendor that carries these? I have placed a note in the Parts Wanted section as well, but have not received any responses yet. The shaft area where the shock slides over is severely corroded. Here is a picture of the part I need (unpainted one on the left). http://community.webshots.com/photo/109000222/2551863670052948230otCxph Thanks. Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#57559 03/08/2006 7:33 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | cujo8 - I may be all wet here but can't you drill out the existing stud and replace it with another bolt on type shock stud. You should be able to get one at your local FLAPS. Just a thought. George | | |
#57560 03/09/2006 1:28 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | George, I will look it to it. Thanks.
Jim
