| | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 |  Have a question that I hope some of you with more wrench turning can answer for me . I need to re-due the kingpins  on TOTO a GMC 1 1/2 ton . Being a somewhat of a lazy cuss  at times , can I swap a good front axle assembly off of a Chevy 1 1/2 ton onto a GMC without any problems/modifications  ? I know that GMC did things differently than Chevy on some of it's mechanicals so one needs to be careful about what you swap . Thanks  ED H | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | im not 100% positive, but i believe that i read that the rims on the GMC's are lug centered, and the chevys are hub centered.. at lest for some years? not sure might want to look in to that | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | Thanks corpo , Toto has hub centered rims . Just looked at both axle assemblies and visually they look identical , forgot the tape measure to make sure , oh well . ED H | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | GMC and Chev both used hub piloted wheels and they will interchange. GMC also used stud piloted wheels. I'm not sure if Chev did. However, if you find a Chev with hub piloted wheels, the wheels will interchange with your GMC. I can't really tell from the pictures of your 303 what kind of wheels they are. | | |
