| | | Forums66 Topics128,195 Posts1,057,377 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 27 Apprentice | | Apprentice Joined: Feb 2008 Posts: 27 | I have a carb that leaks at the shaft which connects and rotates the butterfly prior to the exhaust manifold.
I see reman carbs for sale, but they don't seem to have this part, part of the reman.
Has anyone resealed, reshafted/milled or found a reman part?
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Are you refering to the throttle shaft inside the carburetor base, or the heat riser valve that is inside the exhaust manifold?
Both can be repaired, but neither is included in a carburetor kit.
Harvester | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it is leaking out the throttle shaft it is flooding. You need to check the float & needle & seat. Make sure you have a filter to keep dirt out of it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | An out of round hole for the throttle shaft will not cause a leak, but that is where a leak will usually show up at. Wrenchbender explained the cause of the leak. However, if you do have an out of round hole, it will be a source of a vacuum leak and performance will be improved by fixing them. I use a small hole gauge to measure the bore like I use for measuring valve guides. The bore will be egg shaped instead of bell mouthed like a valve guide. I ream them out to the size bushing I happen to have, install the bushing and then ream the hole to fit the shaft | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Those shafts bores can be repaired pretty easy with a good reamer and some bushings. I have done a few with good success. But the real problem is flooding. There should be no fuel leaking from them, if anything its a vacuum leak with air entering causing a lean condition.
Joe | | |
