0 members (),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | thanks guys, I have a delco-remy alternator with 4 terminals: a big terminal "bat",another "grd" . In the center top a little window with two terminals: left "R" and right"F". The regulator have 4 terminals: IGN, FLD, ARM and BAT in top right. PLEASE, how to connect them? The alternator was revised and it is ok, the regulator is new. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I don't have a lot of experience on alternator conversions, but I did convert to an alternator also. The alternator I'm using has an internal regulator, so you no longer need the stock regulator. My understanding is that most alternators have internal regulators. Classic Parts (Chevy Duty), sells a conversion harness with connection directions that is pretty simple to install. Also you can do a search on this forum, I got lots of great information and links from a couple of threads about this conversion. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I would get a Delco 10SI,which is an alt. with the regulator built in and you won't have to worry about hooking up an external reg. A 10SI would be like what came on a 76, 77,78,chevy. Then things would be simpler for you. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | If you choose to use the external regulator setup, I believe one of the wires to the regulator needs to have a resistor wired in series with it, or the engine will continue to run when the ignition is turned off. It's been a long time since I've done one of those conversions, but I seem to remember that the idiot light circuit will back up enough current to bypass the ignition switch if it's used with an ammeter instead of a "no charge" light. The internal regulator unit works a lot better. Jerry
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | alfonso, While I'm certainly not an expert, your regulator terminal ID's don't fit the usual numbering for the proper unit. The typical regulator for use with the alternator is commonly numbered F-2-3-4. Could you have the wrong voltage regulator? I have linked a picture that shows typical wiring for that 10DN alternator and it companion regulator. As was mentioned above, you could switch to a 10SI or newer alternator for probably less than the cost of your old alternator and new regulator, and be done with the potential headaches that sometimes accompany the firewall mounted regulator...just a thought! http://rowand.net/shop/tech/images/alternatorwiringoverview-1963to1972buick.jpgStuart | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Alfie - Stuart is correct, the reg should be numbered,if you've got the larger rectangular regulator labeled as you say sounds like you have a reg for a generator system - I put a freebie alternator with ext reg on my 58, looks like so, no idiot lite, don't recall any resistor or resistance wire, been working fine for ages Bill | | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Thanks guys, Stuart and Bill are right, I don´t have the right one. I´m going to follow the Stuart advise and buy one like the 10SI. Alfonso | | |
