2 members (Wheelie, Jimmie D),
125
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57457 03/06/2006 6:38 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I have the original 235 in my 55.1. We rebuilt the engine 2 winters ago. I am getting an oil leak that seems to be in the front of the engine, low down. What are the likely sources of the leak. Thanks - Scott
55 1st Chev.
#57458 03/06/2006 6:53 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Pan at the front main,cam chain drive cover to front of eng, and seal where crank goes threw cover. | | |
#57459 03/06/2006 6:55 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | And oil gally plug at front driver side by generator | | |
#57460 03/06/2006 7:17 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I have seen small knock in or knock out plugs, like a small freeze plug, used to seal the oil galley at the front of the engine. These type of plugs are a possible source of a leak because they are not threaded plugs. These plugs will present some oil leakage directly above the front cross member. At the other end of the oil galley, they can also cause some oil leakage at inside the bell housing. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#57461 03/06/2006 9:13 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Mine was leaking around screws that fasten down the timing gear cover. You need to pull those screws out and seal the threads, I used teflon paste type, cured the problem. | | |
#57462 03/07/2006 6:43 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks T-ruck, jiMerit, and 6 cyl. Those all sound like likely suspects. It gives me a few good places to look. Thanks agin - Scott
55 1st Chev.
#57463 04/22/2006 11:22 AM | Joined: Feb 2006 Posts: 29 Apprentice | | Apprentice Joined: Feb 2006 Posts: 29 | has any body had problems with oil and water leaking out the clutch cover on a 235? | | |
#57464 04/22/2006 9:53 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That same oil galley goes down the left side of the block from front to back and has another plug at the back. There could be some leakage of oil there, but if your getting oil and water, I'd say the head gasket may be leaking at the rear of the head and that oil and water could be running down the back of the block into the fly wheel cover. Joe
#57465 04/24/2006 10:19 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | FYI Jim Carter sells a sleeve to correct a leaking crankshaft front seal.
Mike Barnes 1950 GMC 1-ton pickup
