8 members (Wally / Montana, Otto Skorzeny, TUTS 59, Jon G, JW51, 3800GUY, cmayna, 52GMC35424JD),
107
Mod | | | Forums66 Topics128,065 Posts1,055,865 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57433 03/06/2006 1:13 AM | Joined: Dec 2005 Posts: 62 Member | | Member Joined: Dec 2005 Posts: 62 | Hi Folks,
If I change my engine from the 216 to a "modern" 235, can I still use the Carter W-1 Carb?
Jeff | | |
#57434 03/06/2006 4:34 AM | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | The internal venturi on the W-1 is too small to support the extra cubic inches well at wide-open throttle. However, you could use two W-1's Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#57435 03/06/2006 5:50 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I hate to disagree with the carbking, but a W1 came stock on the 1941-49 truck splash 235s, and I have used them many times on the later 235s using the 216 manifold, and they worked well.
See the USA in your vintage Chevrolet! My Blog | | |
#57436 03/07/2006 4:15 AM | Joined: Dec 2005 Posts: 62 Member | | Member Joined: Dec 2005 Posts: 62 | The reason I asked the question in the first place is because I thought that I read somewhere that the only change needed on the 235 from the 216 was the waterpump but I couldn't find the source again. Thanks for the help!
Jeff | | |
#57437 03/07/2006 6:20 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 216 carb has a smaller bolt pattern than the 235, and the ports where the manifold bolts to the head are also smaller. When I use a 216 manifold on a 235 I make adaptor ring for the head so the 216 alignment rings can be used.
#57438 03/07/2006 12:34 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | My own experience agrees with Carbking.I used a 216 Carter when I put a 235 in a 45 Chevy 2 ton.Later I replaced the Carter with a crappy old 235 type Rochester B which gave a noticable improvement at full throttle.This may be less obivious on a lighter truck not used to carry loads. | | |
#57439 03/07/2006 2:44 PM | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | The W-1 utilized a main venturi of 1 1/4 inch. The later 235 CID engines utilized a main venturi of 1 5/16 inch.
1/16 inch difference may not seem like a lot; but the total airflow difference is about 15 percent more (when you do the math, remember to subtract out the area on the boosters).
Perhaps my original post in this thread was hasty, and did not offer sufficient depth. The W-1 carb will work on the 235 (and work well at low and moderate loads). However, the engine cannot perform to its potential under full load wide-open throttle with the smaller carburetor.
And Dave, we don't disagree, we just needed to define the terms of discussion more accurately. My fault for the initial hasty post.
