| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 15 | Could someone tell me if a 63 2wd long bed panel truck would fit on a 65 long bed 4x4 pick up frame?
thanks, fran | | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | I believe it will the cabs and beds are the same just the doors and windshields are different. I'm building a 64 long bed that i've had for 20 yrs or more and just bought a 66 to get the bed and frame. I took the running gear from a 85 c-30 and put under the 66 frame. anyways i'm pretty sure their the same
| | | | | Joined: Aug 2009 Posts: 12 New Guy | | New Guy Joined: Aug 2009 Posts: 12 | I miss read your question sorry, I didn't see panel, I'm not sure about that sorry. Look at both frames and do a little measuring. Also measure the wheel base, make sure you look good at where the arch starts on the long bed and see if it is the same on the panel.If you have to move the rear axle, that's not really a big job. Best of luck with it,that will make a nice truck, I have always liked the panels too. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Could someone tell me if a 63 2wd long bed panel truck would fit on a 65 long bed 4x4 pick up frame?
thanks, fran what I did miss(but due to your lack of model ident) is that what you are calling a long bed panel is a C30 133" w/base and a long bed 4 x 4 would be a k20 127"wb; therefore different frame lengths ron | | | | | Joined: Sep 2009 Posts: 35 Apprentice | | Apprentice Joined: Sep 2009 Posts: 35 | yes they are the same just different bodys but all these were built in an assembly line fashion and they did not have seperate lines for every make/model just different bodies/parts for those lines depending upon the "run " of the particular vehicle..... | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | apart from frame length, you'll find that the pickup frame doesn't have the riveted on body mounting brackets for the panel body, need to get them from the panel frame
Bill | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | yes they are the same just different bodys but all these were built in an assembly line fashion and they did not have seperate lines for every make/model just different bodies/parts for those lines depending upon the "run " of the particular vehicle..... how can they be the same frame, different w/base. they may look the same except that one is a little longer then the other. ron | | | | | Joined: Feb 2006 Posts: 15 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 15 | As cool as a 4x4 panel would be...i think i'll just look for a good long bed pick up body to put on this frame. I dont feel like modifying that much to get this done. Thanks for the info guys! | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | As cool as a 4x4 panel would be...i think i'll just look for a good long bed pick up body to put on this frame. I dont feel like modifying that much to get this done. Thanks for the info guys! 4 x4 panels were pretty scarce. I have one 115"W/base. they were the only panel produced as a 4 x 4. they didn't make a panel at all at 127" w/b(3/4t}. they did make a panel at 133"w/b(1t) but only as a 2 wheel dr ron | | |
