5 members (Robert Crandall, Danielbolt, Phak1, Bill Hanlon, 1 invisible), 325 guests, and 5 robots.
Topics128,156
Posts1,057,021
Members48,460
If I put the new higher speed rear end in will it affect the transmission? if I cruise at 60 mph will it damage the transmission designed to go only 45?
Mike,
In general, No, you will not damage the transmission cruising at 60 mph with a 3.55 conversion.
You might put some wear on the clutch in 1st gear, if you have a 3-speed (and depending on the way you engage the clutch).
Tim
Thanks Tim,
