| | | Forums66 Topics128,156 Posts1,057,017 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 83 | If I put the new higher speed rear end in will it affect the transmission? if I cruise at 60 mph will it damage the transmission designed to go only 45? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mike,
In general, No, you will not damage the transmission cruising at 60 mph with a 3.55 conversion.
You might put some wear on the clutch in 1st gear, if you have a 3-speed (and depending on the way you engage the clutch).
Tim
| | | | | Joined: Jul 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 83 | | | |
