1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#574173 09/14/2009 9:44 PM
Is the 1955 1st series differential the same as the 1955 2nd series? I'm thinking about swapping my torque tube rear for a complete 1955 open drive rearend but I want to make sure I'm getting the right axle.
1953 3100 | 1958 3/4-ton NAPCO
graydon #574187 09/14/2009 10:34 PM
ODSS President
ODSS President
tt is 4.10, open is 3.90. All you need to do is swap the differential itself, the axles are the same on both units. for instance I have been using '49 axles for 10 years with a '57 3.90 differential. I do use an overdrive with this giving me a final drive of 2.73; that is .70 X 3.90 = 2.73
~ Cosmo
1949 Chevy Half Ton
Cosmo #574225 09/15/2009 12:26 AM
The ratios of standard 1955-1st and 1955-2nd 1/2 ton trucks are the same, 3.90:1 (unless you have the 55-2nd RPO overdrive rear end: it would have 4.11:1 ratio).
Also, 1955-1st 1/2 ton trucks had an open driveshaft (1954 was the last year for the 1/2 ton torque tube).
Tim
I think graydon might be asking about rear-end-width (drum-to-drum) and maybe spring mounting.
1955-1st compared to 1955-2nd
See if this chart from the Tech Tips helps.
http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
Drew
