Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, UtahYork, 66flea), 163 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
Junior Member
Junior Member
I need to replace the 3.73 ring and pinion with 3.08's (or?) in my '66 pickup... How difficult is the set up part??? Can't seem to find a local shop interested in doing it... Am a pretty good wrench, but this is just one of those things I've never done and I'm a little nervous about screwing something up.
Never give up!
3B Offline
Hy donny, the setup is not that difficult,if you have a shop manual just follow the instructions, The new pinion should have some numbers inscribed on it these are your initial setup shim thicknesses, also there might be a prefered backlash figure, always use all new bearings and seals, hope this helps and good luck, if you run into problems just ask us some more questions.
if you are going to do this mail me...doc
Z
Z Offline
you can't.you need a different carrier.
Junior Member
Junior Member
Please expand on this.... Do you mean 3.08's aren't available or....? This is a 12 Bolt rear end....
donny
where what part of the country, do you live
Jim & Caroline
You used to be able to buy a spacer
or was that going the other way??it,s been about 30 years
Z
Z Offline
3.73 and up uses one carrier,3.42 and down uses a different carrier.if you had a 3.08 carrier you could use a spacer to use a 3.73 gear.not the other way around.
Junior Member
Junior Member
Quote
Originally posted by carolines truck:
donny
I'm near Goldendale WA - hwy 97 North of the Columbia river.
Junior Member
Junior Member
BTW - my handle changed - was already registered as Doctor Dogg.... So they kept that one.... Anyway - I'm hearing that there's no way I can do 3.08's with this carrier - how do I get a higher rear end for highway cruising? Do a complete rear end swap??? If I have to keep the 3.73's this thing will be a major gas sucker and is running too high at highway speeds.... Options? Ideas? Thanks!
Z
Z Offline
go to the link pape and look up randys ring and pinion.call them and see if they can help.
What transmission do you have? If an auto you could use a 700 or 200 and if a standard you could use an old Borgwarner OD unit or a T-5. The first two would give you a 2.61 final and the T5 would give a 2.98 final. Just something to think about since it would keep the 3.73's for trailer pulling or heavy loads but give shallow gearing for highway cruising. This option is more pricey than a R&P swap, but a lot more versatile.
Evan
Junior Member
Junior Member
Well, thanks to all!!! I've found a complete rear end from a '68 Suburban that is supposed to bolt right up to my rig in place of the stocker. Apparently, these are pretty hard to find. The trans swap idea is a good one, but with the 3 speed 350 in now, I can downshift if I hit bad hills. Not likely to do much towing. Again, I appreciate all the input and have learned a lot from this experience.... More to come with the swap, I'm sure, and will report my mileage changes. Thanks again! Doctor Dogg (donny)
