2 members (Otto Skorzeny, KingG), 53 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#57393 03/04/2006 11:06 PM
okay so i got the front end completely removed for cleanining and new bushings etc,,, and i decided to pull the pan off the 235 to clean it and the pump, and got to looking at the cam.....i saw the lobe that works the fuel pump looks worn,,looks like a groove in it about 1/8 inch thick...is this normal? :confused:
#57394 03/05/2006 3:19 AM
i'm kinda new to these 235's/261's but ive never seen a cam with a 1/8" groove in it..
#57395 03/05/2006 5:32 AM
I've worked on alot of 235s and I have never seen what you described. Sounds like a pump locked up at some point.
My Blog
#57396 03/05/2006 5:34 AM
Usually means someone ran it without enough oil.
Fred
52 3600
69 C-10
#57397 03/05/2006 5:51 AM
The 56 motor I'm rebuilding had a nasty looking lobe where the fuel pump rides also. Had no history on the motor, other than it was running when pulled. I replaced the cam and lifters anyway.
You never have enough, til you have too many!
#57398 03/05/2006 10:39 AM
okay ...thanks guess i will add that to the growing list....does it ever stop when a guy is trying his darnest to revive the ol girl!!!
