7 members (Jay R, Rosco, ArtA, Still At It, greenie-reddy, Samantha, moparguy),
84
Mod | | | Forums66 Topics128,287 Posts1,058,544 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Anybody tell me if it's posible and if it's been done already? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It would have to come out of an S-10 that had the 4.3 V6, the 4 cylinder and 2.8 V6 transmissions won't bolt up to the 292.
Bill Burmeister | | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | thanks for the answer. any paticular year on the 4.6V? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any year would do. The 4.3 has the same bolt pattern as the 194/230/250/292 6, as well as the Chevy V8s.
Bill Burmeister | | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | thanks for the info, its going in a 53 1/2 ton. I've owned it since 1974, the third owner. I'm looking for a through frame steering box. Would you have any idea on this or what to use? | | | | | Joined: Aug 2008 Posts: 38 'Bolter | | 'Bolter Joined: Aug 2008 Posts: 38 | Thanks for that bit of info. Now I have one more part to put on my shopping list at the local wrecking yard that usually has the good pieces.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | any reason your not looking at a 700R4 from behind a V8 vs the V6? It the trans was slated for the V8, it got less discs and steels and a longer spacer (lower torque capability)
Late model V6's used the 4L60e which will require a transmission controller.
| | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | s10 auto would have to be from a 4.3L v6, 2wd 1988 to 1992. and it would have electric speedo, but you can swap it out to gear driven easy enough
50 chevy 3100
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | .see link below if you mean T5 and automotive [like astro van] trans + S-10, not automatic ????? transmission
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
