0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#573544 09/12/2009 12:02 PM
Hey guys. I need a little help. I have a 61 with a 283 and a 2g 2barrel carb. I had a problem with the float sticking I believe because there was gas pooring out of the carb after about 10 seconds of running. I replaced the float and problem solved. The truck had a bad hesitation when you stepped on the gas before and after the float so I installed an hei which impoved but did't corrent the problem. I dialed in the air/idle setting using a portable tac (i don't have a vacume gage. Truck ran almost perfect. After a couple of days in the garage i noticed it putting off a very strong gas smell. Turns out I now have gas coming out of my passenger side exhaust pipe. I tried leining it back out and no change. Any Ideas? Carb is clean and not very old at all to begin with. Like I said the truck is running nearly perfect so its not missing a cylinder to give me raw gas. thanks for any help in advance
61nate #573578 09/12/2009 4:06 PM
Apprentice
Apprentice
Check your oil for gas contamanation.Oil pan might be topped off with a layer of gas.
Jimmy
Oil looks and smells good.
