| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I have a 261 head which I want to sell. Its casting # is 3836850. I put it on Ebay, and someone asked if it was a standard head or a high compression head. I have tried searching for this info with no luck. Does anyone know how to identify the different 261 heads? Thanks, Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | IIRC, the "high comprssion" 261 head is in reality, a 235 head. I'm wanting to say that was more of a Canadian Pontiac thing, not a truck application.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chris,
3836850 is the code for a standard USA truck 261 head (54-62, low compression).
The Canadian Pontiac 261 might have had a high compression head, but the Canadian truck 261 and the USA truck 261 had a lower compression head than was used on a 235.
The person who asked about a "high compression head" on a 261 might have been referring to a high compression "848" (3836848) 235 head (1956-1962) that was/is often adapted for use on a 261 (by drilling 6 additional coolant passages in the head).
Tim | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | so that's what the 848 on my head means - high comp? but what does that actually mean in the long run to me and my '61 block? | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Tell the buyer that head 3836850 can be modified to equal the compression of the 3836848 (high compression) head by facing off 3/32".
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Milling off 3/32" brings the intake valve right down to the piston, removes part of the combustion chamber's original shape, and (if you don't have enough adjustment) requires shorter pushrods. | | |
