6 members (Woodcmiami, Gdads51, Gib70, Peggy M, Cosmo, 1 invisible), 94 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#573476 09/12/2009 1:53 AM
I have a 261 head which I want to sell. Its casting # is 3836850. I put it on Ebay, and someone asked if it was a standard head or a high compression head. I have tried searching for this info with no luck. Does anyone know how to identify the different 261 heads?
Chris
IIRC, the "high comprssion" 261 head is in reality, a 235 head. I'm wanting to say that was more of a Canadian Pontiac thing, not a truck application.
Bill Burmeister
LONGBOX55 #573519 09/12/2009 4:22 AM
Chris,
3836850 is the code for a standard USA truck 261 head (54-62, low compression).
The Canadian Pontiac 261 might have had a high compression head, but the Canadian truck 261 and the USA truck 261 had a lower compression head than was used on a 235.
The person who asked about a "high compression head" on a 261 might have been referring to a high compression "848" (3836848) 235 head (1956-1962) that was/is often adapted for use on a 261 (by drilling 6 additional coolant passages in the head).
Tim
tclederman #573521 09/12/2009 4:36 AM
so that's what the 848 on my head means - high comp? but what does that actually mean in the long run to me and my '61 block?
rednate #573559 09/12/2009 2:31 PM
Tell the buyer that head 3836850 can be modified to equal the compression of the 3836848 (high compression) head by facing off 3/32".
You Tube
Curt B. #573566 09/12/2009 3:14 PM
Milling off 3/32" brings the intake valve right down to the piston, removes part of the combustion chamber's original shape, and (if you don't have enough adjustment) requires shorter pushrods.
