7 members (1955 1 Series, WICruiser, Otto Skorzeny, carbking, Peggy M, Danielbolt, 1 invisible),
113
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,152 Posts1,056,825 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | Hi, I need to replace the headlight buckets on my '56 GMC model 150 pickup. I know I can get 'em from parts vendors, but I am putting it back on the road as quickly and and as inexpensively as possible. I'm scrimping on everything but the brakes. Does anyone know if any later model truck or car buckets will fit? I may just need to go to the junkyard with a tape measure.
thanks, Dave
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 55-59 GMC or Chevy truck will fit, a post in the parts wanted should turn one up .... can't imagine what else would mount the trim ring or allow proper light aiming
Bill | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | 58/59 are different because 58 is when dual head lights came out. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | geez cren, of course they are, what was I thinkin .... too longa shifts right now  the 55-7 GMC and Chevs will be what ya need Dave, oughta be easy enough to find Bill | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | I'm almost sure the headlight bucket is the same on a 55-57 Chevy car, Pontiac, Buick & Olds also. Fred
