7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl),
112
Mod | | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 10 New Guy | | New Guy Joined: May 2008 Posts: 10 | 58 gmc with 270, 3 speed standard is in the truck now. I'm putting a 70 Pontiac 350 and th400 in it. I'm looking for motor mount sources as well as trans cross member sources and suggestions on the simplest way to make this change.
I can get in there and fabricate what I need to do, however, if something already exists and will work well, I'd rather just go that route. Any other suggestions would be appreciated.
thanks JD | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | any of the vendors will have conversion mounts that will work, same as Chev, adds a cross member for the engine and another for the trans - see hereBill | | |
