3 members (FishinToms53, ShopRag, Stovebolt48), 88 guests, and 0 robots.
Topics128,049
Posts1,055,634
#573331 09/11/2009 2:54 PM
58 gmc with 270, 3 speed standard is in the truck now. I'm putting a 70 Pontiac 350 and th400 in it. I'm looking for motor mount sources as well as trans cross member sources and suggestions on the simplest way to make this change.
I can get in there and fabricate what I need to do, however, if something already exists and will work well, I'd rather just go that route. Any other suggestions would be appreciated.
thanks
JD
any of the vendors will have conversion mounts that will work, same as Chev, adds a cross member for the engine and another for the trans - see here
