1 members (Tronman),
110
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | How can I find out if my on my fenders on my 47 are original or after market fenders.
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I can't tell you exactly, but my driver side on my 55.2 chevy is aftermarket and my passenger side is original. The differences I see is that the original has thicker metal, it is heavier and doesn't wobble when I pick it up (obviously separated from the truck). The original has a loose support on the inside of the fender where it bolts to the upper radiator support. The repo has it welded in. You know where the front edge of the hood lines up with the fender? Well, the repo one has the metal overlapping while the original is formed. Now if someone fills over this (like I plan to) you will not be able to see it. I hit the side of the repo with my four finger tips and it vibrates more than the original. So, have a confused you more? | | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | definatley thinner metal if its aftermarkey. also if your truck is totally stock,never modified, there might be a hearty dose of undercoat. there was penty of that on my truck. preserved most of the metal
2000 Nissan Frontier, 3.3L (sold) 2006 Chevy Cobalt SS, 2.4L 1952 Chevy 1/2 pickup, 235 c.i. I6 when life speeds up, downshift
