| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 22 | Can anyone tell me why my vent window flops back and forth w/o any resistance?? Thanks, Mark | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The tension spring is either not properly adjusted or is broken. You can access it by taking the dor panel off through the forward hole in the door. I beleive it's a 9/16 nut. You'll have to carefully pry the lock tabs up befroe you sdjust it.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 22 | Thanks for the explanation. I'll try it in the morning. Mark | | |
