Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (electech, 78buckshot, rfs56trk, Mike1933), 71 guests, and 4 robots.
Topics128,283
Posts1,058,519
Members48,490
sps
Offline
Anybody tell me if it's posible and if it's been done already?
It would have to come out of an S-10 that had the 4.3 V6, the 4 cylinder and 2.8 V6 transmissions won't bolt up to the 292.
Bill Burmeister
sps
Offline
thanks for the answer. any paticular year on the 4.6V?
Any year would do. The 4.3 has the same bolt pattern as the 194/230/250/292 6, as well as the Chevy V8s.
Bill Burmeister
sps
Offline
thanks for the info, its going in a 53 1/2 ton. I've owned it since 1974, the third owner. I'm looking for a through frame steering box. Would you have any idea on this or what to use?
Thanks for that bit of info. Now I have one more part to put on my shopping list at the local wrecking yard that usually has the good pieces.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
any reason your not looking at a 700R4 from behind a V8 vs the V6? It the trans was slated for the V8, it got less discs and steels and a longer spacer (lower torque capability)
Late model V6's used the 4L60e which will require a transmission controller.
s10 auto would have to be from a 4.3L v6, 2wd 1988 to 1992. and it would have electric speedo, but you can swap it out to gear driven easy enough
50 chevy 3100
.see link below
if you mean T5 and automotive [like astro van] trans + S-10, not automatic ????? transmission
Jim & Caroline
