3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#57338 03/04/2006 1:19 AM
My steering wheel squeaks whenever I turn. Not loud but for a few seconds. Doesn't affect anything but I would like to silence it. Does anyone have a simple solution without me having to pull the wheel off?
Thanks.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#57339 03/04/2006 1:37 AM
WD40?
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#57340 03/04/2006 2:39 AM
Apprentice
Apprentice
I agree that a shot of lubricant at the junction of the wheel and the steering column has a good shot at taking care of your squeak. I'd advise against WD40, though. Since it's not actually a lubricant, but a water displacer, It might work but not for long. A teflon based lube will work a lot better.
-Jon
Jon
1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
#57341 03/04/2006 3:10 AM
Was thinking along those lines but my concern was for any electrical contact. As it is stock 49 wheel/column the only contacts I have are the horn connections.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#57342 03/04/2006 8:47 AM
Lubrication is the answer there is a bushing which is in the upper half of the colum tube. This is also part of the horn circut. A dry lube like graphite woul work well and not attract dirt or dust to the bushing area and will not harm the horn contacts.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#57343 03/04/2006 9:07 AM
WD-40 is indeed a light lubricant. Arrgh...I'm getting tired of the rumor that it isn't. I think it had to have been started by the 3-in-1 oil people, or maybe the people who sell spray lithium grease.
1954 GMC De Luxe COE
#57344 03/04/2006 2:54 PM
Riding in the Passing Lane
The horn contacts are probably whats squeaking.
1972 Chevy c10 Cheyenne Super
#57345 03/04/2006 8:55 PM
GMCPanel, Gee don't have a cat, WD-40 is indeed a light weight lubricant, it is a petrolium based spray which was intended as a spray lube to displace moisture hence the WD - 40 (Water Displacement formula 40). But as with any oil based lubricant it will attract dust and dirt. I still use it anyway but for areas which are dust and dirt sensitive I use a dry lube.
wink grin grin
#57346 03/04/2006 9:17 PM
Ex Hall Monitor
Ex Hall Monitor
I agree that you need to try a lubricant but I wouldn't recommend any oil based lubricant in that area. I would try silicone spray. It will flow until the carrier evaporates and it won't attract & hold dirt that turns to gunk (there's a highly technical term for ya) like WD 40 and the others will.
#57347 03/07/2006 12:19 AM
Thanks all. I sprayed a bit of lubricant (no it wasn't WD40) between the wheel and the shaft and I don't squeak anymore, neither does the wheel. The horn still works.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
