2 members (Shaffer's1950, 1 invisible),
36
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57338 03/04/2006 1:19 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | My steering wheel squeaks whenever I turn. Not loud but for a few seconds. Doesn't affect anything but I would like to silence it. Does anyone have a simple solution without me having to pull the wheel off? Thanks. | | |
#57339 03/04/2006 1:37 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 |
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#57340 03/04/2006 2:39 AM | Joined: Jul 2005 Posts: 34 Apprentice | | Apprentice Joined: Jul 2005 Posts: 34 | I agree that a shot of lubricant at the junction of the wheel and the steering column has a good shot at taking care of your squeak. I'd advise against WD40, though. Since it's not actually a lubricant, but a water displacer, It might work but not for long. A teflon based lube will work a lot better. -Jon
Jon 1942 Chevy 3/4-ton Special
I don't need instructions. I have a hammer.
#57341 03/04/2006 3:10 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Was thinking along those lines but my concern was for any electrical contact. As it is stock 49 wheel/column the only contacts I have are the horn connections. | | |
#57342 03/04/2006 8:47 AM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Lubrication is the answer there is a bushing which is in the upper half of the colum tube. This is also part of the horn circut. A dry lube like graphite woul work well and not attract dirt or dust to the bushing area and will not harm the horn contacts.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
#57343 03/04/2006 9:07 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | WD-40 is indeed a light lubricant. Arrgh...I'm getting tired of the rumor that it isn't. I think it had to have been started by the 3-in-1 oil people, or maybe the people who sell spray lithium grease. | | |
#57344 03/04/2006 2:54 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The horn contacts are probably whats squeaking. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#57345 03/04/2006 8:55 PM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 |
#57346 03/04/2006 9:17 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I agree that you need to try a lubricant but I wouldn't recommend any oil based lubricant in that area. I would try silicone spray. It will flow until the carrier evaporates and it won't attract & hold dirt that turns to gunk (there's a highly technical term for ya) like WD 40 and the others will.
#57347 03/07/2006 12:19 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks all. I sprayed a bit of lubricant (no it wasn't WD40) between the wheel and the shaft and I don't squeak anymore, neither does the wheel. The horn still works. | | |
