Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 71 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#57311 03/03/2006 8:26 PM
iam puting 350 in place of 235 do i need a standard crank where the truck is a 3 speed or will it be fine
bill
Junior Member
Junior Member
Huh?
Well let me see if I have the question right, I had to consult my cards for a clairification of the question. :confused: :confused:
Replacing a 235 in line 6 with a 350 V8 will the stock 3 speed trans bolt to the new V8 motor without modification?? Not an expert but I would think some modification would be in order. Someone with more info will no doubt correct my thinking if it is incorrect. smile
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
What years?
"It ain't a truck if you can't hose out the cab."
do i need to change the crank in the 350 to take a pilot bearing to bolt the 3 speed to 350
bill
you should be able to put pilot bushing in any crank,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
The pilot bearing for a 350 should be fine, you will need a different you may need a different trans bellhousing for a v8 depending on the year of the truck. More info on vehicle would be helpful.
62 carry all the 350 is out of 76 pickup automatic
bill
#57319 03/03/2006 11:33 PM
Riding in the Passing Lane
Just get a pilot brg. or bushing for the 350. It will fit the crank & trans. Get a 55 up v-8 or 63 up 6 cyl. bell housing & flywheel.
1972 Chevy c10 Cheyenne Super
