| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57311 03/03/2006 8:26 PM | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | iam puting 350 in place of 235 do i need a standard crank where the truck is a 3 speed or will it be fine
bill
#57312 03/03/2006 8:54 PM | Joined: Oct 2004 Posts: 15 Junior Member | | Junior Member Joined: Oct 2004 Posts: 15 | | | |
#57313 03/03/2006 9:16 PM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Well let me see if I have the question right, I had to consult my cards for a clairification of the question. :confused: :confused: Replacing a 235 in line 6 with a 350 V8 will the stock 3 speed trans bolt to the new V8 motor without modification?? Not an expert but I would think some modification would be in order. Someone with more info will no doubt correct my thinking if it is incorrect.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
#57314 03/03/2006 9:22 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 |
"It ain't a truck if you can't hose out the cab."
#57315 03/03/2006 9:31 PM | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | do i need to change the crank in the 350 to take a pilot bearing to bolt the 3 speed to 350
bill
#57316 03/03/2006 9:36 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | you should be able to put pilot bushing in any crank,,brian | | |
#57317 03/03/2006 9:38 PM | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | The pilot bearing for a 350 should be fine, you will need a different you may need a different trans bellhousing for a v8 depending on the year of the truck. More info on vehicle would be helpful. | | |
#57318 03/03/2006 9:57 PM | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | 62 carry all the 350 is out of 76 pickup automatic
bill
#57319 03/03/2006 11:33 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Just get a pilot brg. or bushing for the 350. It will fit the crank & trans. Get a 55 up v-8 or 63 up 6 cyl. bell housing & flywheel. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
